Link Tiger Touch to Lightconverse
Danert
Postby Danert » 11 Jan 2016, 10:54
Hey guys,
how do I connect my Tiger Touch console to the Lightconverse Software.
yyy898
Re: Link Tiger Touch to Lightconverse
Postby yyy898 » 11 Jan 2016, 13:36
You will need to connect your tiger touch to the computer running light converse using a cat-5 internet cable.
then in the tiger touch go to setup (avo key + disk) then to dmx settings, and then the computer should show up in the artnet area, add that to the desired line and then you just need to change the artnet setting in lightconverse (which i don't know how to do, google it)
zahoorjury
Postby zahoorjury » 25 Mar 2016, 00:32
So you mean that we patch laptop and TT together without any other hardware in the middle , like an Artnet device or like somethings else?
zahoorjury
Postby zahoorjury » 25 Mar 2016, 00:36
And can we send TT Dmx out command via Artnet cable to a lightning software without using any other device in the middle, just a single cable ?
Postby niclights » 25 Mar 2016, 08:54
It usually works best if there is a network switch (or router) between the two.
Users browsing this forum: Google [Bot] and 37 guests
