Pearl 2004 new Version
Mcyf12
Postby Mcyf12 » 08 Feb 2006, 12:40
Hi, i recently got to use a Pearl 2004 with Version 1.2. But it seems to "lag" quite abit, meaning it's reaction seems retarded, compared to the older version. What cld be the cause of this?
Postby niclights » 08 Feb 2006, 13:55
Can you elaborate further?
Programming/Takeover mode/Normal mode/palette recall/add/swop etc.
I have found that each revision has worked faster than previous, although after long programming sessions there can be a slowdown. Desk reset cures.
iadwm
Postby iadwm » 10 Feb 2006, 10:27
Check that MIDI (user settings 14) is NOT set to Visualiser.
(if your not running Vis - obviously...)
John Peel
www.iadwm.com
