Flash in Cue List
erickkrau
Flash in Cue List
Postby erickkrau » 26 Jun 2015, 13:26
I'm getting a strange behavior on cue lists after updating to v9. I always used cue lists as cue stacks of effects. For example, one cue list containing 9 different dimmer shapes. Then I created a key profile setting one key to Go and one to flash. The flash function always worked in older versions, but now the flash does nothing. This happens on my older shows that worked before the update and even if I create a new cue list for the shapes.
Can someone help me with that? It's a function very important to me.
Regards,
Erick
yyy898
Re: Flash in Cue List
Postby yyy898 » 05 Jul 2015, 20:23
please mail the show file to jonasnijs@gmail.com and ill check it for you
wizzman
Postby wizzman » 21 Oct 2015, 14:41
I am also having trouble making this work, is there a solution?
chavos
Postby chavos » 21 Oct 2015, 21:28
Same problem with swop button on cue list, with dimmer shape or Key frame dimmer.
Olie
Site Admin
Postby Olie » 23 Oct 2015, 16:29
Change the shape mode to LTP in the user settings not overlay.
Postby niclights » 23 Oct 2015, 16:57
Olie - that should be the solution be it doesn't appear to work (either for normal or keyframe shape). It does look like an issue.
