We all know the USB (Pearl2004) socket isn't implemented from a software point of view, but is it powered? Is power even supplied on a device port? I don't want to order my USB lava lamp if it isn't.
Cheers,
Andy
USB power?
USB power?
John Peel
www.iadwm.com
John Peel
www.iadwm.com
The USB port on the pearl is a device port and not a host port. In the USB standard only host ports provide power. You will also notice that when trying to plug in your USB lava lamp the socket is the wrong shape.
I suggest that maybe you could plug the Lava lamp into the 4 way strip that the desk is powered from.
Thanks Ollie, helpful as always....
So I will need to cut of the usb plug and put on a 13A plug?
(at least it will be fused
(for those completely lacking in common sense, this is a joke and not to be taken seriously)
John Peel
www.iadwm.com
John Peel
www.iadwm.com
Yes, there are all kinds of dinky devices, NONE of which we can use with our Pearls!
Unless, I got a powered hub - then I could cover my B faders with all sorts of crap....lights, fan, keyboard vacuum cleaner....cup warmer...
John Peel
www.iadwm.com
John Peel
www.iadwm.com
bergcrane2
The USB powered hub was and is much easier!
Although from the amount of 'rude' comments I get from Sound, I wonder if it's worth it....
It is.
Andy
It is.
Andy
John Peel
www.iadwm.com
John Peel
www.iadwm.com
