Avo + daslight vis
samesam3
Avo + daslight vis
Postby samesam3 » 18 Jun 2015, 18:17
Hi everyone,
Just a quicke, can i use avo consoles together with the Daslight visualiser both running accordingly?
For instance, programming with tiger touch and see what im doing at the same time with Daslight visualiser.
Sorry for the bad english.
:lol: :lol:
Thanks alot!!!
Richard :) :) :)
Re: Avo + daslight vis
Postby niclights » 18 Jun 2015, 18:32
This forum is for the Avolites Visualiser. You really need to ask Daslight your question. Although as far as I was aware, Daslight is a control system like Titan with it's own visualiser that only works with that system. You might be better off looking at something like Capture Argo, Light Converse and Realizzer.
yyy898
Postby yyy898 » 14 Aug 2015, 15:52
Dashlight uses the easyview visualiser.
if you have a dongle of dashlight you will unlock the full mode off the visualiser.
open the easyview software from the pc (not from the dashlight software) and look at the bottom right where it says easy view, if it doesn't say demo mode then you can link your avolites with it.
go to universes patch and then artnet.
now you can link your console to the softwae using artnet.
another option if your dongle has dmx in is to use that port, again go to universes patch and then select your dongle dmx input or output and use a male -> male connector.
Whitout a dongle you won't be able to unlock the full mode and you won't be able to use the universes patch, so then you can't link to your console.
