Chase into Show
skogason
Chase into Show
Postby skogason » 02 Jan 2006, 10:43
Hi!
Is there a way to import a chase from a disk into a show on the Pearl2004?
If so, how?
Thanx!
Olie
Site Admin
Postby Olie » 04 Jan 2006, 10:14
No, would be nice though. The difficulty comes with the fact that you can not ensure the patch is the same.
skogason
Postby skogason » 04 Jan 2006, 10:46
ok. Thanx!
skogason
Postby skogason » 18 Jan 2006, 15:52
But why is there, when you press "Disk", an option called "Import Chase"? :?
Postby niclights » 19 Jan 2006, 00:20
It is to import from a PC.
Quote from 2004 Manual:
F [Import Chase] – You can import a matrix chase created on an external PC application using this feature. To import a chase, insert the disk containing the chase you wish to import and select this option.
However, I have never understood the function. I don't think it was ever documented before.
Does such an application exist and if so how does it work?
Phil
Postby Phil » 19 Jan 2006, 10:59
Yes it does... I think Shad created it for someone years ago. It basically allows you to set up a matrix of generics and easily design chases to run over them from memory. I can't actually remember how it works or anything since I only saw it briefly!
iadwm
Postby iadwm » 20 Jan 2006, 08:04
It was a custom update for LD Dave Gibbon and Darren Parker at DPL...
The whole thing is explained in a bit more detail here....
http://www.avolites.org.uk/avonews/pres ... e_park.htm
( I only know because we are all Sarfenders! )
John Peel
www.iadwm.com
Postby niclights » 20 Jan 2006, 13:29
I knew about that show & the custom software, but from (questionable) memory the import function was available long before that.
Awesome show from Mr. Gibbo though. Very jealous!
iadwm
Postby iadwm » 20 Jan 2006, 14:47
Ok - I thought the two were linked a little more intimately....
Oops - I meant the software and <import chase> NOT Gibbo and Darren.
(another one for the lawyers! )
John Peel
www.iadwm.com
Users browsing this forum: Baidu [Spider] and 40 guests
