Fixture list suddenly empty
Clayton
Postby Clayton » 24 Jan 2015, 18:05
I am on Titan Mobile 8.1.
Suddenly, when I attempt to patch fixtures into my current show, the “select fixture manufacturer” list now shows only one manufacturer, and only one profile (an older profile that I created myself). :?:
I’ve tried downloading and re-installing the current personality library from (http://personalities.avolites.com/) but nothing changed. My next step will be reinstalling the entire Titan suite.
Other suggestions on how to fix?
Thanks!
Re: Fixture list suddenly empty
Postby Gregory » 24 Jan 2015, 18:16
There is probably an error in one of your custom personalities which is preventing the software from indexing the library. Start by moving all files out of the directory in your documents folder, check each one in turn to find out which is the culprit.
Clayton
Postby Clayton » 24 Jan 2015, 18:20
Yep. You are exactly right. I created a personality this morning that is apparently problematic. Thank you!
Users browsing this forum: Google [Bot] and 19 guests
