eurolite rgb 252/10
PhilDunford
eurolite rgb 252/10
Postby PhilDunford » 28 Nov 2014, 13:36
I'm trying to patch this led wash strip into a show.
I have found the personality for it and it seems to work OK, but when I set up a state and attach it to a playback, it will trigger into action ok from the fader, but taking the fader down will not turn it off again. I assume this is because it does not have a true dimmer attribute as such.
Could anyone suggest how I should set it up so the fader turns it on AND off?
This is on a Titan one.
New to this, so any help appreciated.
danhoff
Re: eurolite rgb 252/10
Postby danhoff » 28 Nov 2014, 14:51
Press the 'playback options' softkey, click your playback, chose 'release mask', set it to 'local' and then toggle color so it 'includes color'.
PhilDunford
Postby PhilDunford » 28 Nov 2014, 16:47
Thank for that, will give it a try.
A lot to learn...
Postby niclights » 29 Nov 2014, 01:18
Release will only make it return to the previous active state/palette or locate values.
If you want to fade LTP channels by fader you need to set the playback to mode 2 via [Edit Times]. Normally any RGB fixture without a dimmer will have a virtual dimmer assigned so this should not be necessary. However, in the case of multi-cell fixtures where there is a master dimmer but no cell dimmers there will not be a virtual dimmer on the individual cells.
Users browsing this forum: Google [Bot] and 105 guests
