Add fixtures to a cuelist?
akepaulsson
Postby akepaulsson » 16 Nov 2014, 13:13
Is there a way to ad fixtures to an already made cuelist? The reason is that a want to program a complex timecoded show and it would be easier to first make a cuelist with all the fresnells, pars etc and then add moving heads. (sort of building the show layer by layer). Or is there an easier way?
jojodadj
Re: Add fixtures to a cuelist?
Postby jojodadj » 16 Nov 2014, 16:13
You can programme the cuelist then go through each cue one by one and merge the moving heads in. Or if you are using tracking you can turn the moving heads on in the first cue then it will track through until a block cue is seen.
Joe
