questions about pearl 2010 problems
hideljm
Postby hideljm » 02 Oct 2014, 05:53
Hello
i'm using pearl 2010 and i think it's lastest version of sw.
I have two problems to solve.
First one is about clock. In system mode, you know you can set the current time and date right?
when i set the chrrent date and time it works fine.
But several days after, i can find out that the time isn't correct. it's getting faster.
so after few weeks, it's 2 or 3 minutes faster than currnt time.
i keep reset the time but same happens.
i was thinking that because of low internal battery RTC is not working properly. but i can't find the replacing the internal batt in the manual.
Second problem is numeric keypad.
few days before numeric keypad 7 doesn't work well.
when i trying to number '70' , i have to push keypad 7 several times to number '7'. and sometimes when i press kegpad 7 only one time, there's 77 on the lcd screen. it was really fraustrating me and i thought it's mechanical problem which i used keypad 7 too much.
But i was wrong. yesterday when i press keypad 7, it worked totally fine like others. Then i realiseed that keypad 2 is not working properly like keypad 7 did it before. So i can find out that it's software problem.
This is all i can find out. i need yor help.
Please give some advise .
thank you.
clublights
Re: questions about pearl 2010 problems
Postby clublights » 02 Oct 2014, 06:00
Here is the info on the battery change out
http://www.avolites.com/Portals/0/Downl ... 010029.pdf
The keypad sounds hardware to me still ..
I would check all connections inside the desk .
Postby niclights » 02 Oct 2014, 09:26
You can test keypresses by going to System/[Service]/[Diagnostics]
hideljm
Postby hideljm » 02 Oct 2014, 11:20
thanks for replying.
Are there any pictures how to open inside the console and which one is a motherboard.
It's really affraid to look inside without any information.
please give some advise.
Thank you.
clublights
Postby clublights » 03 Oct 2014, 08:39
If your that unsure I'd contact your local distributor for assistance.
Users browsing this forum: No registered users and 60 guests
