cant understand what im doing wrong..
gnagis
Postby gnagis » 30 Jul 2014, 08:50
i have tryed request a personality for my "china" lamp...
but what i can see they have not made annything on that site for 1 week now.?
so i tryed to understand the personality builder and i think i did correct but its not working...
some functions are working but for exampel tilt and pan is not workink.
but color and z rotate are.
can someone please try to create this for me?
or help me what im doing wrong?
my personality file and manueal can be found here: http://tempelkarlstad.se/avolite/
manual for it (direct links): http://tempelkarlstad.se/avolite/doc003 ... 02b0_1.pdf and http://tempelkarlstad.se/avolite/doc003 ... 02b2_1.pdf
would be verry happy for anny help with this as soon as posible :)
Re: cant understand what im doing wrong..
Postby icke_siegen » 03 Aug 2014, 17:13
From what I see you set the locate values for P/T speed to 0% - that's why the lamp is not moving.
However, I sent you an edited version by PN.
gnagis
Postby gnagis » 04 Aug 2014, 08:16
Hello!
now it works some of the functions.
but for example... to get the light "on" i have to select "Thunder" on the shutter to 255 then it lights on...
if i just select "open" it dosent turn on..
also the zoom / rotation i think is not working.
Thanx for your file sofar, atleast i can use it but not to full potensial
Postby icke_siegen » 04 Aug 2014, 09:53
Hm,
then i am afraid you need to check how the fixture really operates, because the manual is faulty (and the two pages you provided are not very detailled). Quote:
We try to make Z rotate has 4 different position: 0-3. 0 is the zoom position for Z rotate. 3 is the biggest size position for gobos.
Adjusting the locate positions is easy - you can even do this in the show: set the value you want to change, then press <Record>+<Locate>
Of course, if you can come up with verified DMX functions, then I am happy to help fixing the personality.
