Hello Avos!
We use the JB System LED Tubes (mostly in ffect mode) on our Avo Pearl 2004, unfortualy there is not bightness channel existing, that means the LED's are still shining if the Brightness master fader is set to zero.
Is there a possibility to solve the problem?
Is it possible to define a Brightnes Channel?
Thanks for efforts
Hama
JB Systems LED Tube Brightness Channel?
Ok, well as things stand it looks like the only thing you'll be able to do is operate the intensity using RGB mode only.
At presetent channels Red, Green and Blue are all LTP. If you change those channels to HTP this should enable you to have control over them from the Preset Fader.
However the effect mode version of the personality won't allow you to do this as the desk does not control Red Green and Blue as individual channels when in that mode. The best thing to do would be to create a Macro or to continue using your palette.
