Shared to normal?
akepaulsson
Shared to normal?
Is it possible to change a Shared palette to a normal palette?
Re: Shared to normal?
If you have the normal information in the programmer you can just merge that into the shared palette. The resulting palette would have both normal and shared information and would apply the normal information if possible and use the shared information otherwise. If you need to remove the shared information, select your fixtures, get them into the right state (possibly using the shared palette) record over the top making sure that you have the Normal option selected and you choose Replace.
akepaulsson
Thanks Gregory!
Users browsing this forum: No registered users and 68 guests
