Going to run a dance recital where each song will have its own cue list.. Want the default move-in-dark to be early and move-in-dark fade time to be 0 for everything.. Can i pre-set global mid options so that any newly recorded cue list uses my preferred settings? or do i have to change each cue list after i build them?
so i guess in essence i'm wondering if i can change the m-i-d defaults.. because apparently each cue list has its own "Global"..
using pearl expert latest version
thx in advance!
move-in-dark global
Re: move-in-dark global
Not as far as I am aware.
However, the 'global' move in dark setting for cues refers to the mode set for the playback. Since cues default to use global all you need to do is change the setting for each playback:
[Playback Options]/<select cue list playback handle>/Toggle [Move in Dark] until it reads 'Early'.
If you don't press exit you can just go through selecting each playback and toggle in turn, so one button press to select and two taps to get to the early setting.
For the fade time slightly more involved:
- View/<select playback handle>
- Click on the move in dark fade column header to select all cues for editing
- Input 0 on the numeric pad
Repeat for each playback.
forgot about that "main" playback options concept.. this will be fine.. once per playback is no sweat.. thank you!!
Users browsing this forum: No registered users and 153 guests
