Titan Mobile 7.3 and 7.4 - cue list move and copy problem
gis
Postby gis » 12 Mar 2014, 12:22
is anybody experiencing problems with move and copy commands?
Here is a Titan Mobile up-to-date and 7.3 software version on Windows 7 SP1.
I've got a cue list that when is moved or copied doesn't show in the new position, it still shows in the original position instead; but the origin and destination handles reacts correctly to commands such as delete (the handle is said empty or occupied as expected).
I need to close and start again the software to correctly see the effects of my moves and copies.
The problem doesn't show on other similar cue lists, but does apply on every copy of that cue list.
G.
Edit: updated to 7.4, the problem still shows.
Paul Heijkens
Re: Titan Mobile 7.3 - cue list move and copy problem
Postby Paul Heijkens » 12 Mar 2014, 12:41
7.4 is now available
Maybe your problem will be fixed in there I don't know why 7.3 is not downloadable anymore
Postby niclights » 12 Mar 2014, 13:16
Paul Heijkens wrote:7.4 is now available
From the 7.4 release notes:
Bugs Fixed
1. Show data reset after 24 hours:
DMX would stop outputting after 23 hours of continuous use and the software would need restarting to re output DMX. This is now fixed.
This is the only change in 7.4. The problem was found in 7.3 and was considered serious enough to take it down and issue the fix. The issue will only affect users who required more than 24 hrs continuous output.
To OP:
I've not seen this before. It might be useful to see your showfile. If possible please send to nick <dot> morris <at> avolites <dot> com with clear instructions on how to repeat.
gis
Postby gis » 12 Mar 2014, 13:49
Thanks for the answers.
Nick, tomorrow I'm going to send you file and details.
