Titan Mobile bad touch behavior pixel map
inrimartyr
Postby inrimartyr » 11 Mar 2014, 17:41
can someone else confirm for me with a titan mobile setup....While in the pixel mapping screen the touch controls for the sliders and scoll do not respond. I have confirmed this on 7.2 and 7.3 with windows 8 and 8.1. The work around is to click on the box on the right hand side and use the wheels to adjust the parameters.
Re: Titan Mobile bad touch behavior pixel map
Postby niclights » 11 Mar 2014, 18:37
They seem to work ok for me. Are there any other details you can think of? Is this running in a standard windows install or a virtual machine?
inrimartyr
Re: 7.3 upgrade no dmx output Sapphire
Postby inrimartyr » 11 Mar 2014, 20:40
well 7.4 seemed to fix it FWIW...
inrimartyr
Postby inrimartyr » 11 Mar 2014, 20:52
and let me be more specific, this problem was different from the other thread. I just found the bug by trying to compare the slide in the pixel mapper on a pearl xpert to see if it behaved the same as the titan mobile PC. when I would slide the "Zoom" slider up the touch function on the touch wing would no longer respond. That's all. on .4 all is well with grabbing the zoom slider and moving it back and forth in a sense "giving it hell" it continues to respond. sorry for not clarifying
inrimartyr
Postby inrimartyr » 11 Mar 2014, 21:38
standard windows install...all other touch functions work...just the parameters specifically in the pixel mapper window...I thought it could be a windows problem but cannot find any settings that I can alter.
inrimartyr
Postby inrimartyr » 11 Mar 2014, 21:44
simply using the touchpad or mouse works just fine.....
unterberger
Postby unterberger » 13 May 2014, 20:57
I have same problem,
not work in pixel mapper
my configuration:
Windows 7 SP1 updated
Intel I7. ATI5770, 6GB RAM ...
TM 7.5
ELO 2201L touch screen monitor
