LedJ_Quad Par 64.d4
I'm having trouble getting this to work on tiger touch. All looks ok although there is one locate value for colour macro set at 2 and I think this should be 0. I've tried to edit but cant seem to change this value.
At present, locate changes the values but the light remains off. Colour macro will function but cannot get RGBW.
Any ideas. Thanks
Help with LEDJ Quad Par64
Purple Ronnie
Re: Help with LEDJ Quad Par64
Try setting the dmx end to 0 (for attribute color macro, function 'No Func').
Another way: set the display type to 'value 0dp' - then you can select distingt values amd try which one is correct. As for the manual, 'No Func' is correct (0...4) - but this wouldn't be the first manual with slight glitches...
I try to create all personalities with the first function range 0-0 because this error in manufacturers documentation appears to be so common.
To clarify, to adjust this requires editing the personality in Personality Builder.
Try patching as 7 dimmers. Raise dimmer 1 (intensity) leaving all others at zero. Try raising 3,4,5 and 6 in turn. These should give control of red,green,blue and white respectively. If that works then let me know and I'll update the colour macro no func function range.
Purple Ronnie
Thanks for speedy replies.
I will try this when I'm back at the desk on Monday.
Purple Ronnie
Hi. Just edited personality as you suggested with dmx end as 0 in colour macro (No Function ) and all works well now.
Many thanks
Many thanks
Thank you for confirming that. I will get the file updated in the library.
