TM Dongle not found
Beast
TM Dongle not found
Postby Beast » 09 Mar 2014, 20:09
Hi all.
Have just updated two Pcs to v7.3. Have requested and got license for TM on one and T1 on the other. When reversing the licensing procedure Eg: T1 on one, which worked, i get a "Dongle not found" on the other with TM. Tried running USB expert and the panels worked, i could see the values change when moving faders and buttons, so TM connected. Also tried the licensed T1 and worked too. Any suggestions?
Sincerely
Beast DK
Re: TM Dongle not found
Postby niclights » 09 Mar 2014, 21:08
Make sure panel firmware is all up-to-date (Usb Expert/Service).
Beast
Postby Beast » 09 Mar 2014, 21:22
Well, i updated the firmware when licensing on the first Pc, and it didn't show any updates available when checking on the second.... ?
Thanks anyway Nic
Postby Gregory » 12 Mar 2014, 13:35
Please check that Windows is using the correct drivers for the Titan Mobile as follows:
  • Ensure the Titan Mobile is connected to your PC using the top connector (A).
  • Open Device Manager.
  • Expand the category called System devices.
  • Right click on Avolites Security Key and select Update Driver Software...
    • If Avolites Security Key does not appear, expand the category called Avolites and check if TM-MB appears twice.
    • Usually it is the second one that you need to update but if you select the wrong one it will not do any harm.
  • Select Browse my computer for driver software.
  • Then select Let me pick from a list of device drivers on my computer.
  • From the list select USB Input Device and click Next.
  • Once the driver has finished installing close the dialog and Device Manager.
  • Start the Titan Mobile software.
Beast
Postby Beast » 13 Mar 2014, 16:58
Thanks Gregory.
This fixed it :D
Sincerely
Beast DK
Users browsing this forum: Baidu [Spider] and 23 guests
