Pearl 2004 sim not working on Win 7
Mbttd
Postby Mbttd » 19 Dec 2013, 16:10
Hi All,
I have a machine running Win 2007 and i have been working with the Pearl 2004 sim for a while now. About a month ago it just stopped working. When you stare the software it gives me a screen likethe one in the attached file.
I have done the following;
1. Uninstalled the sim
2. re installed the sim
3. uninstalled the sim then went through the registry to make sure there was no traces left.
4. re installed it.
every time i have re installed it i have made sure I was in admin mode, made sure to select windows XP SP3 for compatibility, etc....
no dice, each time i get the strange screen you see. Got any ideas??
A few other pieces of info.
If you will notice thee are no LED indicator lights on the buttons. if you click on them it will appear, nothing else happens. the LED does not lighten up just stays dark (EI normal state)
Faders do move
Roller does move
nothing gets put out on the "CRT"
Key switch moves
wheels move
Pearl 2004 screen shot.jpg (218.7 KiB) Viewed 11417 times
Re: Pearl 2004 sim not working on Win 7
Postby niclights » 19 Dec 2013, 16:19
My only thoughts are could it be related to a display setting? Maybe unusual custom DPI text size or the overall size? Something along those lines. I'm only guessing but I know these things have been relevant in the past and an innocent change like this could explain why and when it started going wrong. I'm running some custom themes here with cleartype on and it works fine but I do have default size (100%).
Winston72
Postby Winston72 » 21 Dec 2013, 18:15
I will keep working on this.
It would be really nice to be able to have this sim working. If you have any other ideas please post them here i will be looking in on it.
thank you and happy holidays
What ever you do, Make sure you have fun doing it or it is not worth it in the end.
Mbttd
Postby Mbttd » 22 Dec 2013, 18:22
A quick question regarding this issue,
Does the Pear Sim use the SQL Data base??
Postby Gregory » 22 Dec 2013, 18:29
No, Pearl Simulator does not use an SQL database.
Mbttd
Postby Mbttd » 22 Dec 2013, 20:49
Cool, Just a thought, Was trying to track down the things that have changed on my computer that may have caused the sim issues.
Users browsing this forum: No registered users and 6 guests
