Timecode problem
pbulder
Timecode problem
Postby pbulder » 16 Sep 2013, 23:50
Hello
Little issue here
Want to run certain que's in a quelist to be activated by TC
When i for example have a quelist with 5 que's,
Que 1 thu 3 are manually triggered, que 4(tc 00:00:15:00) is triggered by TC
and que 5 manually again
When TC Starts running there's no problem. The time of que 4 passes by and the que gets activated nicely.
then i manually activate the last que, still fine.
End of song(TC stops running) time stops at for instance at 00:00:20:00
When i kill the fader que 4 is automaticly beeing fired
Guess this is some sort of failsafe system for when you lose your TC signal for a moment while in a fully TC triggered show.
That works great, But for me it's a nightmare.
Is there a solution for this?
Talked with someone from avo about this a couple of months ago(can't remember who)
But he never heard the problem before
Greets Piet
Olie
Site Admin
Re: Timecode problem
Postby Olie » 17 Sep 2013, 12:17
You have two options, either you disable the timer from the timecode menu or properly stop the MIDI timecode. I am pretty sure that you have only paused the timecode which means the timecode is still being sent just the same time is sent over and over. This basically means you are killing the playback and the timecode is telling it to fire straight away. If you disconnect the MIDI cable it will stop the timecode and you should be able to kill the playback.
pbulder
Postby pbulder » 18 Sep 2013, 22:24
Not realy an option for me,
Some songs start so quickly after the other that i dont have time to connect/disconnect any quelist
Isnt it there a possibility (perhaps in the future) that TC work on a WYSIWYG principle.
So if a TC passes by it activates the que and thats it!
