Pearl Tiger ~ include external PAN & Tilt Values via DMX
vajrasana
Postby vajrasana » 22 May 2013, 20:25
Hey there!
I'm writing a program tracking a person on stage with moving heads.
Its output should be DMX.
I'm going to insert those calculated positions into the Pearl via "DMX input".
Now the Pearl should adopt the sent DMX values for PAN & TILT for my fixtures.
Is the pearl able to do that?
If yes, please how?
I’m thankful for some help or a hint ;-).
Vajrasana
Re: Pearl Tiger ~ include external PAN & Tilt Values via DMX
Postby icke_siegen » 22 May 2013, 20:59
I assume you want the Pearl to route through your external values - and unfortunately the answer is no. You can only read and record the input statically, using Include.
vajrasana
Postby vajrasana » 23 May 2013, 10:27
Thx!
You're right...
StijnS
Postby StijnS » 23 May 2013, 19:33
You could use a Luminex Art-Net DMX node, with it's custom merging functionalities, you can map other channels to the pan and tilt of a fixture.
