Clicking Open Workspace and selects e.g "Positions", window wont open on external screen.
The same for all other workspace windows.
Any ideas, known bug?
Thanks!
/Jocke
Pearl Expert Titan 6.1 Workspace wont open
Re: Pearl Expert Titan 6.1 Workspace wont open
The only reason I could think of is the windows do open - but on a display which is not there. E.g. if you have both displays enabled (in System->Display Setup), and e.g. the positions window was previously open on the external display, and currently there is no external display, but only the touch wing, then the positions window would open, but you cannot see it. To solve this, go to System->Display Setup, and disable all displays which aren't currently - physically - present and connected.
As a quick cross-check, try some of the shortcuts, e.g. <View>-<Pan/Tilt> for the positions windows, or <View>-<Fixture> for the fixtures window.
Almost certainly is because wing is set to enabled. Note that you can select/move/resize workspaces using softkeys from the window options menu (view/[options]).
