Adding Windows
CSmithDesign
Adding Windows
Postby CSmithDesign » 21 Mar 2013, 15:31
I have all of my workspaces recorded into soft keys on the main screen workspace (TM). I've noticed that when press the factory-default windows, either from the executor buttons or the soft keys, it adds the new window to my existing windows. This is very helpful for when I use the "fixture attributes" window, I just add it to the workspace, use it, then get rid of it when I'm done.
However, every time I record a new workspace, it deletes every other window and then adds the new windows that I recorded. Can I set it up so that some buttons just add a window in to my existing work space like the factory default ones?
Postby niclights » 21 Mar 2013, 16:06
When recording workspace shortcuts there is a softkey toggle option for 'leave windows on recall'/'remove windows on recall'. Note there is also an option here to toggle between recording only visible windows or all.
CSmithDesign
Re: Adding Windows
Postby CSmithDesign » 24 Mar 2013, 15:37
Got it, I'm guessing that the toggle for recording visable windows only will decide whether any buried windows get recorded as well? Meaning, windows that are behind other windows and you can't currently see them...
Re: Adding Windows
Postby niclights » 24 Mar 2013, 15:38
Yes.
