Running smoke machines from Titan
In a place where I do some programming they've got four smoke machines (one dmx channel each). I've set them up to run manually on the faders, but it's really difficult to make it work well as their each location need a different amount of smoke... Is there any way to timer them or run them with a dimmer shape or something? I know the best solutution would be to use hazers instead, but that's not an option now...
clublights
clublights
The way I read the macro solution was to provide a button, or buttons you can press that will then fire the smoke for the required amount of time at a specified level. If they need to automatically fire then a chase or cuelist would be the way to go. Maybe even a combination of list and macro if you like.
