USB power?
iadwm
USB power?
Postby iadwm » 08 Jan 2006, 17:41
We all know the USB (Pearl2004) socket isn't implemented from a software point of view, but is it powered? Is power even supplied on a device port? I don't want to order my USB lava lamp if it isn't.
Cheers,
Andy
John Peel
www.iadwm.com
Olie
Site Admin
Postby Olie » 09 Jan 2006, 10:48
The USB port on the pearl is a device port and not a host port. In the USB standard only host ports provide power. You will also notice that when trying to plug in your USB lava lamp the socket is the wrong shape.
I suggest that maybe you could plug the Lava lamp into the 4 way strip that the desk is powered from.
iadwm
Postby iadwm » 09 Jan 2006, 14:16
Thanks Ollie, helpful as always....
So I will need to cut of the usb plug and put on a 13A plug? :wink:
(at least it will be fused :shock: )
(for those completely lacking in common sense, this is a joke and not to be taken seriously)
John Peel
www.iadwm.com
Olie
Site Admin
Postby Olie » 10 Jan 2006, 09:47
I sore a USB cup warmer in PC World the other day. Would be helpful for those long programming sessions! A USB beer tap would be better though!
iadwm
Postby iadwm » 10 Jan 2006, 14:43
Yes, there are all kinds of dinky devices, NONE of which we can use with our Pearls!
Unless, I got a powered hub - then I could cover my B faders with all sorts of crap....lights, fan, keyboard vacuum cleaner....cup warmer...
John Peel
www.iadwm.com
dombleu
Postby dombleu » 19 Sep 2007, 03:32
The pearl 2008 got a usual usb connector. I guess this is good news for you lava lamp!
Dominic
bergcrane2
Postby bergcrane2 » 19 Sep 2007, 13:52
You could run an AC line with your snake and hook it up to a dimmer channel. That way you could regulate the heat and lumens of your lava lamp.
iadwm
Postby iadwm » 19 Sep 2007, 21:04
The USB powered hub was and is much easier!
Although from the amount of 'rude' comments I get from Sound, I wonder if it's worth it....
It is.
Andy
John Peel
www.iadwm.com
Users browsing this forum: Google [Bot] and 39 guests
