Wheel Mapper not holding Assiginments?
Dereklites
Postby Dereklites » 07 Sep 2012, 22:50
Hello all who care.
I've built a personallity for G-lites LED Beam 90... Almost.
The wheel mapper will not hold the the assignments?
I have saved it to pesonalities Library to the File and as a seperate file.
I have started a new file and taken one from the Library and changed it.
But it still won't hold the wheel mapper?
anybody.
Postby niclights » 07 Sep 2012, 23:20
Which console/version?
Dereklites
Postby Dereklites » 07 Sep 2012, 23:26
Pearl Expert v6.0
Postby niclights » 07 Sep 2012, 23:43
I think it would be useful if you can explain in a bit more detail exactly what you have tried and what you are wanting to achieve as there are a number of possible errors and it could end up being more confusing if I try to cover them all.
/edit: It might help if you can send me the file.
Dereklites
Postby Dereklites » 08 Sep 2012, 00:00
Its kind of like I said in the origanal message.
I built a personallity from scratch it wouldn't hold the wheel mapping atts
then I tried to take a fixture from the Library that was close as could be
the the one I was building same result. Pan and Tilt are the only thing in 16 bit with a seperate 8 bit Pan and Tilt everything else is 8 bit.
as far as Mode I used 12 channel 16 bit I tried Mode 4 no good and also tried to just go everything 8 Bit.
Thats it.
Postby niclights » 08 Sep 2012, 00:12
Please email me the file.
Dereklites
Postby Dereklites » 08 Sep 2012, 00:26
Sent and Thank you!
