Hello everyone.
I recently attempted to update the fixture library for the Titan software on my Avolites Quartz console.
I downloaded the library version compatible with my Titan software (versions 11.0–11.4). However, after installing it from a USB drive via *Tools > Control Panel > Installers*, I encountered an issue: I am now unable to patch any dimmers or fixtures.
Additionally, a colleague of mine previously—and mistakenly—copied and installed a version intended for Titan 19.0 into the *Personalities* folder on the Quartz console itself.
I am hoping someone here might be able to help me resolve this issue!
Thanks in advance to everyone, and all the best...
Indexing fixture Library
HarunBarucija
Re: Indexing fixture Library
It should not cause any problem if you install the wrong version. The only difference is the visualisation. The installers only include visualisation specific to the versions they cover. If the wrong version is installed you just won't have the latest visualiser library but the various visualiser libraries can coexist. Titan will only use the relevant one.
I have tested this by downloading and installing the v10-11.4 library on a Quartz console running v11.4 and everything seems ok.
I notice the subject of your post is 'Indexing fixture library'. I am wondering if when you posted this it was saying it was indexing in the prompt. It should only index new personalities/modes which is normally fast but if it needs to index the whole library it can take a while depending on the console/version. On a Quartz running 11.4 it can take a few minutes at the moment. It might seem like it isn't working but it will get there eventually.
Does that help?
Does that help?
