Indexing fixture Library
HarunBarucija
Postby HarunBarucija » 21 Nov 2026, 12:37
Hello everyone.
I recently attempted to update the fixture library for the Titan software on my Avolites Quartz console.
I downloaded the library version compatible with my Titan software (versions 11.0–11.4). However, after installing it from a USB drive via *Tools > Control Panel > Installers*, I encountered an issue: I am now unable to patch any dimmers or fixtures.
Additionally, a colleague of mine previously—and mistakenly—copied and installed a version intended for Titan 19.0 into the *Personalities* folder on the Quartz console itself.
I am hoping someone here might be able to help me resolve this issue!
Thanks in advance to everyone, and all the best...
Re: Indexing fixture Library
Postby niclights » 21 Nov 2026, 14:00
It should not cause any problem if you install the wrong version. The only difference is the visualisation. The installers only include visualisation specific to the versions they cover. If the wrong version is installed you just won't have the latest visualiser library but the various visualiser libraries can coexist. Titan will only use the relevant one.
I have tested this by downloading and installing the v10-11.4 library on a Quartz console running v11.4 and everything seems ok.
I notice the subject of your post is 'Indexing fixture library'. I am wondering if when you posted this it was saying it was indexing in the prompt. It should only index new personalities/modes which is normally fast but if it needs to index the whole library it can take a while depending on the console/version. On a Quartz running 11.4 it can take a few minutes at the moment. It might seem like it isn't working but it will get there eventually.
Does that help?
HarunBarucija
Postby HarunBarucija » Today, 08:30
Hello and thank you for your help.
During the patching process—specifically when loading available fixtures—even after waiting for the fixture library indexing to complete, I am forced to manually type in the manufacturer's name.
In other words, no manufacturers appear in the list, even after the fixture library indexing is finished. I tried reinstalling the software currently on the console, but that didn't work.
Do you know of a newer software version that would automatically populate the library with more fixtures and resolve this issue?
Thanks in advance, and thanks again for your help.
Postby niclights » Today, 09:31
This sounds quite strange. Does it work when you type in the manufacturer name?
I wonder if there is something in the custom personalties folder that is causing a problem. Try opening Explorer, navigate to D:\Personalities. If there is anything there delete it (if they are important then you could copy them to a Usb stick first). After doing this restart the software and see if that helps.
If that doesn't help it might be easiest to run a full recovery if you haven't done so already.
HarunBarucija
Postby HarunBarucija » Today, 11:43
Unfortunately, even after entering a manufacturer, I get no results.
I deleted all my profiles and restarted the console (though not the software itself), but unfortunately, nothing happened.
Could you walk me through the steps of the recovery process?
Postby niclights » Today, 11:59
Quartz recovery instructions vary slightly depending on model which can be determined by serial number. You can find this at the bottom of the Quartz support page here: https://www.avolites.com/support/quartz/
You can find the general recovery creator guide here: https://www.avolites.com/support/recovery-creator-guide/
And you can find all the Quartz recovery downloads here: https://www.avolites.com/support/all-quartz-downloads/
