Hi all , I was on someone TT v18 and noticed the the clear and exit button just putting me outside the fixtures selection or programming , but when I reselect the fixture again they were still on their previous values I mean the fixtures attributes should be at their 0% values but none .
How to fix that issue because when to do a new scene I was compelled to do 0% values of all attributes ( no playback fader was active )
What to do ?
Clear & Exit
- zahoorjury
Re: Clear & Exit
This is the normal behaviour. All attributes except Dimmer are LTP and will retain the last value the are set to. Usually this is what you would want. You can set the values of selected fixtures to default by pressing Locate. Alternatively if you set the clear option to 'Release To Playback Values' pressing clear will set the values to the playback level or default if there are not relevant playbacks.
Users browsing this forum: No registered users and 68 guests
