trigger azure 2k from midi foot pedal
jaytech
Postby jaytech » 11 Jun 2008, 20:41
Hi i got an azure 2000 on demo today, I am looking to trigger scenes from a midi foot pedal but what is happening is that the pedals change pages or (banks) only, how do i go one step more to select scenes within a bank?
Postby niclights » 11 Jun 2008, 23:36
From the manual:
MIDI commands used by the Azure
The Azure uses standard MIDI commands. The usual name for these
is given in italics. All commands are given in hexadecimal notation
($9n), where ‘n’ is the MIDI channel number. So a note on command
for MIDI channel 3 for example would be $92.
Set playback page : program change ($Cn xx)
Page  A   B   C   D   E   F   G   H   I   J
xx  $7F $02 $03 $04 $05 $06 $07 $08 $09 $0A
example $Cn $02 Console changes to Page B
Turn on a playback: note on ($9n pp ll)
Note number (pp) = playback number, from 0 - 49 (decimal)
Key velocity (ll) = playback level, from 0 - 127 (decimal)
example $9n $03 $40 Playback Fader 4 at 50% level.
Playbacks on buttons cannot be set at a % level, only playbacks on
faders (1-10 on each page).
(Note that Playback Fader numbers start at zero, so subtract one
from the number on the console to get the MIDI note number).
Stop/run/step a chase etc: after touch ($An pp cc)
Aftertouch value (cc) = control codes:
$00 stop chase
$01 run chase
$02 restart from step 1
$03 fade to next step using programmed fade times
$04 Snap directly to next step
Normally you don't need to worry about all the codes. The important bits are:
Program Change = Change Playback Page.
Note on = Turn on Playback.
Velocity = Playback level.
Aftertouch = Chase controls.
You need to look at the details of your controller to see how you set it up to output what you need.
