stacking cues
dbvenue
stacking cues
Postby dbvenue » 07 Jan 2008, 23:28
Can you stack cues on a avo Pearl 2000 like you can with a hog. We just purchased an Avo and I have not found a way to stack.
Postby niclights » 08 Jan 2008, 00:20
Yes. Just make a chase and globally unlink steps:
Key to program.
[edit times] (softbutton C)/relevant playback SWOP
Link = (softbutton G)
[enter]
In Run mode:
After raising chase playback you fire cues using either [go] or Playback Add (in run mode). Note that for [go] to work you must be connected to the chase. Playback Add should always work but there is a bug whereby you will not be able to use if you change page and the new page does not contain a chase on that particular playback.
You can also specify links and alter timings for individual steps by unfolding the chase.
