Pearl 2004 with PR Pilot575 Wash (Personality problem)?
Tilemachos Andreadis
Postby Tilemachos Andreadis » 06 Dec 2007, 19:13
Hello! I have a Pearl 2004 and I find a problem with the Pearl River Pilot 575Wash. In locate fixture the shutter is closed and the pan-tilt speed is 100%. Actually the screen shows 0% but this is 100%. You have to put the wheel to 100% to have the fastest speed of the fixture.. Is this a personality problem? How can I fix it?
Thanks.. :?: :)
Postby niclights » 07 Dec 2007, 00:25
According to personality PT Speed is set to 100% already. Shutter is 0%.
Locate values are the 11th column, after attribute name. If you need this quickly you can change to required values yourself. Otherwise use Bug Report section of the library. Remember values are raw DMX and not percentage.
2    61   L    1   100   1N   O   1   "Shutter"           0     0     0
1     1   H    2   100   1I   H   1   "Dimmer"          255     0     0
3    61   s    5   100   1N   E   1   "Pan"             128     0     0
0     0   L   12   100   1N   E   1   "Pan Low"         128     0     0
3     1   s    6   100   1N   F   1   "Tilt"            128     0     0
0     0   L   13   100   1N   F   1   "Tilt Low"        128     0     0
4    61   I    4   100   1N   A   1   "Colour"            0     0     0
10    1   L    7   100   1N   B   1   "Cyan"              0     0   255
9    61   L    8   100   1N   D   1   "Yellow"            0   255    51
10   61   L    9   100   1N   C   1   "Magenta"           0     0   255
5     1   L    3   100   1N   Q   1   "Zoom"            127     0     0
9     1   L   10   100   1N   0   1   "Effect"            0     0     0
8     1   L   11   100   1N   0   1   "P/T Speed"       255     0     0
8    61   I   14   100   1N   0   1   "Control"           0     0     0
