palette problem in takeover mode ---URGENT---
powerdesign
Postby powerdesign » 06 Aug 2007, 13:10
I'm on a festival and had programmed some pallets for moving heads.
When I set the pallete fade in time everything works fine untill a certain point where the timing does not work anymore.
Can anyone plese help me? Is this a know problem? Can it be fixed?
Thanks in advance for your quick replies.
Regards, Bert.
Postby niclights » 06 Aug 2007, 19:57
I assume this is Pearl 2000/4?
This is not something I have experienced with latest software although there were older issues where fade times could be ignored after a certain number (5?) of simultaneous fades were already running.
Are you sure you're not activating a playback containing these fixture/attributes and thus overriding?
Please confirm console, software version and exact actions to repeat.
powerdesign
Postby powerdesign » 08 Aug 2007, 14:31
I've checked the software version.
Version 1.1 was installed. Upgraded to 1.2 and no problems anymore.
