colors spinning not simultaneouslyI
csgushen
Postby csgushen » 19 Jul 2007, 02:41
I have a group of fixtures,from these movingheads,I let fixture1 be blue and recorded into PB1.
Then,I made all of fixtures spin colors ,of course include fixture1,and recorded into PB2.
I first pulled up PB1 ,you can see fixture1 turning into blue,then,I pulled up PB2.Something strange happened.Although all the fixtures spined colors simultaneously except for fixture1.
I tested a lot of ways ,still cannot make all spin simultaneously.
Thanks in advance.
Postby niclights » 19 Jul 2007, 15:14
It would be normal for the continuous spin to start from its current position. Therefore if one fixture is in a different colour to the others then it will be out of sync with them when you ask them all to spin.
You need to have a way of ensuring all reset their start position before recalling a spin cue. Either by palette, another playback memory or via a two step chase. When using a chase you can tell it to only run once and adjust the timings so there is no delay between step one (ie. all colours white) and step two (all spin).
