I am trying to preprogram a show which will run on a Quartz. I'm using Titan Go with a T1 (on Windows 11) and struggling to get Winamp to behave correctly. I have patched the Winamp fixture and when I use the attribute editor to select / play tracks they all work fine. However, when I use my cue list to trigger track playback it will often play the wrong track (e.g. if my cue-list has cues for track 1, track 2, track 3, then often when hitting the track 3 trigger it plays track 2). Looking at the winamp window at the same time, it seems to even corrupt the playlist and actually show the wrong track in the wrong position in the playlist, which then resolves itself after stopping playback.
I tried the same thing using Titan Simulator with a Quartz selected and the same issue. Not sure if there's an issue with the plugin, or with my Winamp (I tried different versions), or with my cues! Would appreciate some help!
Winamp playing wrong track
Users browsing this forum: No registered users and 54 guests
