Hi guys!
I'm having trouble with the lighting programming for a show. This show has about 60 playbacks, which aren't used in a cue list, but are instead launched individually from the playbacks window.
Playbacks are recorded as channel but due to a change in the show, a specific attribute of a particular fixture needs to be modified across all 60 playbacks. That atribute is already recorded in every playback, i just need to change the value.
So far, I've been modifying this attribute for each playback individually (set attribute level - record - select playback - combine - REPEAT x60). But its a tedious task (and future shows have +110 playbacks to modify...)
Is there a way to do this across all 60 playbacks at once if they aren't in a cue list?
I tried selecting multiple playbacks at once, but when I click "record," it doesn't let me record an atribbute across multiple playbacks simultaneously.
Thank you all!
Recording an atribute across multiple playbacks at once (Combine)
joanmitorrens
