Busking Setup „Blue-Out“ Scale and Scene Masters
Beisal
Postby Beisal » 22 Nov 2025, 19:42
I use a T1 for live busking on a Windows touch laptop and am thrilled with the software.
However, I have a problem with my working concept and I can't find many busking setups on the internet to inspire me.
Maybe someone has an idea how to solve my specific problem or a completely different approach that would give me a similar result:
I mainly use palettes and presets to quickly create light shows . I have ScaleMaster for all fixture groups on the faders so I can quickly turn them on and off without having to press a lot of buttons.
I'm now looking for a good concept so that at the end of a song in a liveband situation , I only have to press one button to stop all playbacks/FX and switch to a pause lighting mood („blue out“) in which I can prepare the next song and then start it with the push of a button. My main problem now is that the Scale Masters don't really work in this concept because they are above everything else.
I was able to build the following workaround for myself:
I created a cue list (playback mode Cross HTP, so that it also gets dark; button is in the macro window) with the following content:
Cue 1: Blue mood, all lights off (I) except for a few blue bars (I, C)
Cue 2: Macro playbacks in playback window release
Cue 3: Macro scene master enter
Here, the cue list stops and waits for a go, and I can set the new lighting mood.
Cue 4: Macro (recorded myself):Scene Master Commit with 2s Fade In
Cue 5: Macro Scene Master Exit
Cue 6: Macro Release Me
In this configuration, however, the I-value does not fade (presumably due to Cross HTP) but jumps abruptly to the new value when Release Me is triggered. Can this be changed?
I would also like to trigger a macro or something similar in this cue list like “set all Scale Masters to 100%”
I welcome any ideas and suggestions!
kimwida
Re: Busking Setup „Blue-Out“ Scale and Scene Masters
Postby kimwida » 16 Dec 2025, 18:05
Why don't you add grand master on a fader?
I usually bring down the grand master fader at the end of a song.
Then I run a macro which releases all running playbacks.
And I launch the initial playback.
Finally I bring up the grand master fader.
Beisal
Postby Beisal » 16 Dec 2025, 22:28
Thank you for your reply. I'll give that a try. But I think it would be great if you could reset everything at the touch of a button and automatically enter this transition „Blue“ mode.
Apart from the fade out from the Scene Master and resetting the Scale Master, I've already managed to do that.
Maybe someone else has some ideas or can give me a tip as to what the problem might be or whether it's even possible.
kimwida
Postby kimwida » 18 Dec 2025, 01:29
I'm sorry for oversimplifying the answer to your question.
But I can help you about scale master thing.
This macro makes it look as if the Scale Master value in the 5th Playbacks window fades from 0% to 100% over 1 second.
You can find more information over https://www.avosupport.de/wiki/macros/function/group.setgroupfaderlevel.
<avolites.macros>
  <macro id="make_scale_master" name="make scale master">
    <sequence>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.1, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.2, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.3, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.4, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.5, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.6, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.7, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.8, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:0.9, Global.PageSwitchAccuracy)</step>
       <step pause="0.1">Group.SetGroupFaderLevel("Playbacks", 4, level:1, Global.PageSwitchAccuracy)</step>
    </sequence>
</macro>
</avolites.macros>
