Question about keyframe shapes
sarajohnson
Postby sarajohnson » 30 Oct 2025, 09:35
I have a question regarding keyframe shapes. When I create a dimmer effect (e.g., Dim 100.0) on conventional fixtures, all the fixtures first go to full brightness before the effect begins.
How can I make the effect start immediately without having all the fixtures turn on to full at the beginning?
Re: Question about keyframe shapes
Postby icke_siegen » 30 Oct 2025, 19:42
Most likely you have programmed full intensity within the cues. At least in my test I couldn't reproduce this. Here is what I did:
- new show
- patch 4 dimmers, exit patch
- select dimmers
- Shapes & FX, KFS, Create
- @@, Add Frame
- @0, Add Frame, Finish Recording Frames
- Set Spread
- Record to Playback, Clear
Now when I fire the playback, of course some dimmers start (where the effect starts) at full but the others start at 0.
