Good Morning together,
i have too questions.
1. Is it possible a "Record Macro" to edited? I have Macro with a move command and i need this move command in this macro as well.
2. Im new in d Avolites universe an i can´t current write Macro´s. Is here in this Forum a Guy who can write a Macro for me?
This is my wish Macro
Start Macro
Move Playback on Position M1 (Button at the under the little Screen) to Playback Position to 601
Move Macro on Position 11 (on the little Screen at the D7-215) to Playback Position 586
Move Playback on Position 602 to Playback Position M1 (Button at the under the little Screen)
Move Macro on Playback Position 587 to Position (on the little Screen at the D7-215)
Finish
Best Regards
Gruny
Position Change Macro
Re: Position Change Macro
as already mentioned in the FB group:
- the only way to edit a recorded macro is to export it, edit the XML, and then import it again
- yes, such a macro can be written
- in order to write such a macro the locations (the exact names of where the designated playbacks/buttons are located) need to be known. However at the moment I don't have a D7 (where you want this to run on) available. If you want you can send me a showfile with designated cues on those buttons and I'll try to find the correct location strings.
