Movement questions
deanball
Movement questions
Postby deanball » 08 Sep 2025, 11:17
I'm currently using an Avolites Titan Go 17.1 system at my venue and have some questions about unusual movement behavior I've encountered. I've created multiple cues with the shape generator and saved them as "phased," "winged," and "synced" for each fixture group.
I’ve noticed that regardless of the set fade or delay times, when transitioning from phased to synced, the heads seem to start from random positions instead of moving together as intended. All movements are organized in a playback group by fixture grouping, so they should operate independently.
Is there a way to resolve this issue? My fader mode is set to mode 0, with the kill point at "fade out complete." The shape behavior is set to "overlay" (the same reaction occurs when set to LTP), the shape size is assigned to the HTP fader, and both the size and speed sources are linked to their respective masters I created.
Thanks for your help!
