Select more than one fixture with userNumbers or titanId
Discussion and chat related to developing interfaces to the Titan software using the web API.
Hieason
Postby Hieason » 15 Aug 2025, 03:41
so i want to control more than onw fixture in the same time but i don't know what is the group and handleIndexList refer to in this link http://[ip]:4430/titan/script/2/Selection/Context/Global/SelectFixtures?group={string}&handleIndexList={}
and i want to select them with their userNumbers or titanId
anyone can teach me to do it please
Re: Select more than one fixture with userNumbers or titanId
Postby Gregory » 15 Aug 2025, 20:56
The SelectFixtures function takes a handle group string which refers to an area of buttons or faders on the console along with a list of 0-based indexes for the handles within that group. There is a list of handle groups on this Wiki page.
If you want to select using Titan IDs you can use SelectFixturesWithTitanIds.
In theory it should be possible to select via user numbers using either SelectFixturesFromHandles or SelectFixtureHandles although I'm not at a computer currently to check the exact format.
Postby icke_siegen » 18 Aug 2025, 09:36
I tried Gregory's examples, and while some yield in errors like 'cannot cast...', this one does work:
http://localhost:4431/titan/script/2/Selection/Context/Global/SelectFixturesFromHandles?handleList_userNumberList=1,2,3
You see a little caveat here: I am using port 4431, in order to have my sselection reflect in Titan's GUI. In order for this to work you need to add two lines to a config file (see https://avosupport.de/wiki/_media/api_ui_port.pdf for details).
wendellburton
Postby wendellburton » 03 Mar 2026, 08:16
In Titan’s API, group usually refers to a programmed fixture group (the same type you create in the console under Groups). So if you already have fixtures stored in a group, you can reference that group name in the group parameter.
The handleIndexList parameter refers to the internal handle indexes of fixtures in the current show file — not their user numbers. That’s why passing userNumber or titanId directly won’t work there.
