Today I have a request for you to solve another problem ... I am currently creating a new show where I have a different device setup than before. In order not to do everything from scratch, I imported my old show, used Mapper and I have all my stuff. This is where the problem appears - I have many Key Frame shape FX in cuelists and they do not work as they should because of the new number of devices and different layouts.
When I do INCLUDE -> Cue with Key Frame Shape I am able to change Spread, speed etc. but the edit group is empty and adding a group does not work - I can at most remove devices. The only way to improve the effect is to edit each frame of the effect anew which puts the group into the effect but it is very time-consuming. Is there a faster way to do this because the corrections themselves will take longer than doing it all over again? In my previous console it was enough to just select a new group of devices and press UPDATE - everything was fine right away.
quick update key frame shape FX
