Hello!
Today I noticed a strange behavior of Titan 18 - let's say I have a cue where half of the mac quantum is in a specific position and the other half works in the circle effect. When I update the palette with gobo or color, the quantums that are in the circle effect change their working position to a completely different one. It's similar when I have to update this cuelist. At this point I have to release this cuelist and run it again so that it works properly with the new updated palettes. Is this some kind of error or do I have something wrong in the settings?
Edit : I found when this happens - when I have the fader set to Manual crossfader in the cuelist. One more thing - if I select a fixture - then a palette with a gobo that I want to fix, fix that gobo and make Clear, the fixtures are without gobo. If I select fixtures, then fix the gobo to another without first starting a specific palette for editing after Clear, everything is ok.
Strange behavior after palette updates or cue updates
Sethrollins69
Re: Strange behavior after palette updates or cue updates
This behavior sounds like it could be related to how Titan 18 handles crossfader modes with dynamic palettes. Manual crossfader settings often cause cues to temporarily lose the intended effect until the cuelist is reactivated.
