Timecode framerate
karenmiranda
Timecode framerate
Postby karenmiranda » 24 Feb 2025, 07:22
I've timecode a show using winamp (at 100fps)
The smpte source is 30fps, I've noticed the start of the song is in time but it gets more and more out of time as the song goes on.
Is the difference in framerate the problem? If so what's the solution?
Re: Timecode framerate
Postby icke_siegen » 24 Feb 2025, 18:17
Are you using mp3 audio files? Then most likely this is the issue - Winamp outputs wrong timestamps. Try to recode the files as wav - this should solve the problem.
Users browsing this forum: No registered users and 53 guests
