Request CreateOrUpdateMarker to add color parameters
qq914218974
Postby qq914218974 » 11 Nov 2024, 13:29
Request about “CreateOrUpdateMarker” API to add color parameters
e.g.
http://[ip]:4430/titan/script/2/Timelines/CreateOrUpdateMarker?handle={handle}&externalId={string}&time={}&legend={string}&colour={}
Or is there any other API that can set the Marker color in the timeline?
Looking forward reply...
Daniel
Re: Request CreateOrUpdateMarker to add color parameters
Postby Gregory » 11 Nov 2024, 17:12
If you are writing a macro you can write the following:
Handles.SetHaloForHandles(Timelines.CreateOrUpdateMarker(userNumber:1, "Ext1", "00:00:00.01", "Test Legend"), "#ff0000")
The CreateOrUpdateMarker function returns the handle associated with the trigger that was either created or updated, this can be used as a parameter to the SetHaloForHandles function that can set the halo colour for it.
For WebAPI it is not possible to chain function calls together in this way so you would need to run separate commands and parse the returned JSON e.g.:
http://localhost:4430/titan/script/2/Timelines/CreateOrUpdateMarker?handle_userNumber=1&externalId=Ext1&time=00:00:00.01&legend=WebAPI
The above will return the details of the handle in JSON e.g.:
  "titanId": 1829,
  "type": "timelineTriggerHandle",
  "Links": [],
  "active": false,
  "halo": "#FF0000FF",
  "icon": null,
  "information": null,
  "legend": "WebAPI",
  "notes": "",
  "selected": false,
  "userNumber": {
    "hashCode": 0,
    "userNumbers": null
From which you will need to read the titanId that can then be used as follows:
http://localhost:4430/titan/script/2/Handles/SetHaloForHandles?handles_titanId=1829&colour=0000ff
It is also possible to read from the JSON what the current halo colour is using the halo property, assuming it has been set. There is also a property for legend however since that will be set by calling CreateOrUpdateMarker it should just return the new legend.
