Hey!
I’m running Avolites Titan Quartz v17 and I’m trying to achieve an effect where the lights from several pixel bars go from inside to outside from holding a button and go in reverse when I release the button. Is this possible?
What should happen is this:
Holding the button:
1 2 3 4 5 6 7 8 9 10 11 12
And so on… and when I release the button the opposite so…
Cue to release in reverse?
Perriemeister
Re: Cue to release in reverse?
- program a cue with all the fixture at 100%
- press [Edit Time] from the menu, select the cue you have just programmed, and set a fade-in and a fade-out time, e.g. 0.5s, and fixture overlap of 0
- on the next menu page (still in the Edit Times menu) select Fixture Order and set the order to your liking
- on the [Options] tab (on the isplay in the Playback View window) under [Handle] set the Key Profile to Nightclub
- Exit Exit
Now when you flash this cue you have the effect you wanted.
Perriemeister
- Exit Exit
Thanks, that is very close! What I'm missing is the fixtures individual lamps turning on one at a time. Now the whole fixtures lights up but I want this wave effect with one individual light from one fixture to light up.
It's like this:
12345 12345 12345
12345 12345 12345
but I want this:
12345 12345 12345
12345 12345 12345
12345 12345 12345
Is that possible?
I think so, yes. Which fixtures exactly are you talking about? Then I could try and give detailled instructions.
Perriemeister
icke_siegen wrote:I think so, yes. Which fixtures exactly are you talking about? Then I could try and give detailled instructions.
Cameo PIXBAR 600 PRO
Users browsing this forum: No registered users and 97 guests
