Changing group layout from macro
KarrnDragon
Postby KarrnDragon » 06 Jun 2024, 18:28
Hi Forum,
I'm struggling to understand why I can not move and rotate the layout of the group from my macro.
I've written the following simple macro:
<avolites.macros xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:noNamespaceSchemaLocation="Avolites.Menus.xsd">
  <macro id="Avolites.Macros.TestRotate" name="TEST ROTATE">
    <description>Test of macros</description>
    <sequence>
        <step>ActionScript.SetProperty.Integer("Group.Editor.Layout.PositionY",5)</step>
        <step>ActionScript.SetProperty.Integer("Group.Editor.Layout.PositionX",10)</step>
        <step>ActionScript.SetProperty.Integer("Group.Editor.Layout.Rotation",180)</step>
    </sequence>
  </macro>
</avolites.macros>
I'm using the macro like this:
* Open Group layout editor of my group
* Select group
* Activate macro
I can see in the programmer display that Position Jumps to X = 3, Y = 11 and Rotation = 180° like I specified in the macro, but the view in the layout editor does not change. If I move the wheels it updates.
Am I forgetting anything or is this a bug?
Observed with a Titan Mobile and Titan v17.
Best Regards
Re: Changing group layout from macro
Postby Gregory » 14 Jun 2024, 00:44
The properties mentioned, e.g. Group.Editor.Layout.PositionX, are used to output to the wheel display UI. As such setting them does not change the properties of fixtures in the group, in part this is because the value shown just represents one of the selected fixtures (the context fixture).
Instead you can call one of the following functions:
Group.Editor.IncrementWheelParameter(0, 1, 0, false, true, false)
Group.Editor.IncrementWheelParameter(0, -1, 0, false, true, false)
Group.Editor.SetWheelParameter(0, 8, false, false)
The first two examples will increment or decrement the X position of the selected fixtures by one, the latter will set the X position of the context fixture to 8 while maintaining the relative positions of the other selected fixtures.
Since the first value is the wheel index (0-based) you might need to ensure the wheels are displaying the expected values.
