Hi all,
V16 Titan Simulator
While i generate a PDF report from Patch, I just get an empty folder without the .pdf
HTML and etc works fine
Any suggestion? Thanks
Can’t generate PDF Report
Re: Can’t generate PDF Report
My immediate solution would be to export it as HTML, open this in a browser, and print/save this as pdf from the browser.
If you want to really solve this then I'd start with the logs (log viewer/log collector). Exporting pdf files depends from a library called wkhtmlpdf - maybe something went wrong when this was supposed to be installed?
