Pearl 2004 not full on
gomes
Postby gomes » 14 Jan 2007, 12:20
when i patch a dimmer and slide the channel fader up the channel reaches 255 on the output,
when i store this into a memory playback it only reaches 254?
how can that be? :?
Regards, Gert-Jan
Postby niclights » 14 Jan 2007, 12:38
Memory Master not on full?
Test faders is System/Service/Diagnostic Screen
gomes
Postby gomes » 14 Jan 2007, 13:27
hello,
"Test faders is System/Service/Diagnostic Screen" This is all good
Master fader also(bypass in menu), i read the output on a artistic licence microscoop3.
In the pearl screen i also see these numbers.
when i use the weels, to program the dimmers, the memory playbacks give 255 on the outputs.
when i use the channel fader, 254 is the max on a memory playback
when i use the channel fader direct to master there is 255 again on the meter?
The problem seems to be in the programmer. from fader to memory playback
regards, Gert-Jan
