PC suite v16 show on TTPro v15.1
outputaudio
Postby outputaudio » 10 Apr 2024, 21:17
I searched the forum with many strings and the Avo website but i cannot seem to find my answer
So perhaps a doubled question:
Can i program a show in PC Suite v16 and run it on a TTPro v15.1 ?
If so, can i use Go or do i have to use the Simulator
Re: PC suite v16 show on TTPro v15.1
Postby Gregory » 10 Apr 2024, 21:34
Generally speaking show files are not backwards compatible so if they have been saved in version 16.0 it probably won't be possible to load it into the version 15.1. In some cases where it has been a point release it might for example be possible to load a v9.1 show file into v9.0 software but it it safer to program in the version of software you intend to use.
In this case if you are able to uninstall v16 from the PC and install v15.1 to do your programming. You can always reinstall v16.0 later on the PC and that should be able to load the v15.1 show file.
outputaudio
Postby outputaudio » 11 Apr 2024, 16:14
Thanks! I had this feeling this was the case. But as the show is Saturday and i dont have the TTPro in advance i wanted to know before starting programming
outputaudio
Postby outputaudio » 12 Apr 2024, 12:05
Update:
I was lucky to get my hands on the TTpro yesterday and i was able to load a show which was pre-programmed on PC Suite 16, loaded onto a Quartz 16.0 to add some more pre-show programming and saved back on my USB
The TTPro with 15.0 loaded the show without errors
